Problems "Websocket Error Undefined" suddenly?
    Hello Guys.
    Suddenly, i'm getting the error "Websocket Error Undefined" when opening the SmartVisu page - after pressing refresh a couple of times, it works again.... But if it then works, and entering a "Room" - the connection get lost again when returning to the main page.
    I've searched some threads, but i can't find an answer i can use..... Udklip.PNG
    Has anyone an idea?
    I'm using the Raspberry pi image.
    I'm using Chrome currently - but on iPhone 6 and iPad same problem appears.
    Did you check if smarthome is still running on the Pi? Maybe the service crashed.
    sudo service smarthome status
    Zuletzt geändert von DerSeppel; 15.06.2015, 12:03.
      Hi Rasmus,
      if you are on a Raspi then the chances are high that your SD-card is about to give it up. The first thing I would do was to make a backup of your data. If you can be sure that your SD-card is fine I would continue the search elsewhere...
      Regards,
      Bernd
        Hi Rasmus,
        I have a similar effect when I enter a room's page for the first time and go back to the main page. In that case I get the same websocket error. After hitting "refresh" once, everything works fine again. Smarthome has not stopped working and it is definitly not a problem of the SD card. However, it is reproducable.
        Sorry I cannot help but at I can at least confirm the problem on the Pi image.
        Cheers,
        Alex
          Okay, it could be the sd card - I can do a check... But the error has been there for over half a year now... Just hasn't used it.. The smarthome is running correct, all the logics is executed as it should....
