Ich bin nun auch auf 2.8. Habe aber leider Probleme mit dem sql Plugin. (smarthomeNG 1.2.442.dev)
plugin.conf
log nach dem Start:
Hab ich etwas vergessen?
plugin.conf
[sql] class_name = SQL class_path = plugins.sqlite_visu2_8
2016-10-04 11:04:27 ERROR Main Plugin sql exception: No module named 'plugins.sqlite.upgrade' Traceback (most recent call last): File "/usr/local/smarthome/lib/plugin.py", line 63, in __init__ plugin_thread = PluginWrapper(smarthome, plugin, classname, classpath, args, instance) File "/usr/local/smarthome/lib/plugin.py", line 108, in __init__ exec("self.plugin.__init__(smarthome{0})".format(args)) File "<string>", line 1, in <module> File "/usr/local/smarthome/plugins/sqlite_visu2_8/__init__.py", line 93, in __init__ import plugins.sqlite.upgrade ImportError: No module named 'plugins.sqlite.upgrade'
