Homeserver 4 Gira
    Homeserver 4 Gira
    Hi
    In one of my project, I work by ETS 5 (you know it that upgrade to 32 Group adress) I used all this group (0 to 31)
    when I programming the HS 4.5 I founded a big problem. Expert 4.5 allowed just added 16 GA to give
    What can I do to solve this problem?
    any body help me?
      You can only use Groupadress up to 15.
      Higher GA´s are not possible with the HS.
        so I have use 2 HS for this project?
        Is it possible????????????????????
          No. HS does not support these adresses at all.
          P.S. One ? is enough. More than one is not polite.
            So if you want to use the HS you have to change your adressstructure.
              tanks
