Gira Transponder and keypad problem
    [Elektro] Gira Transponder and keypad problem
    Hello,
    i've got a problem and maybe someone can help me.
    I've attached a Gira Keypad and Transponder to an audio door station stainless steel. All worked ok for some weeks.
    Suddenly, the keypad and transponder suffered major problems:
    - Keypad does sense the touch of the fingers only sometimes and only on some numbers (already replaced the keypad without success).
    - The transponder works sometime and sometime not.
    The door station works flawlessy, instead.
    I noticed that when i switch the audio control device in programming mode, only the transponder led starts blikning, but not the keypad led.
    I suspect some wiring problem or weaking signal.
    I have 2 audio door station, 3 audio home station, 1 keypad, i transponder and 4 additional switching actuators.
    The wiring is made by 0.5mm shielded cable, in a star configuration.
    Can someone give me a tip to solve the problem?
    Thanks!
    Problem solved.
    Wiring cables was too small and cable was too long.
