Hager QuickConnect and stranded wire
    It seems that Hager is phasing out screw terminals for some of their products - for example RCBO ADA916D is now discontinued and replaced with ADS916D with QuickConnect push-in terminals. Using spring clamps are probably beneficial as they increase assembly speed (and thus reduce cost) and spring ensures sufficient pressure on the contact long term.
    However, unlike Wago and Phoenix terminal blocks Hager MCB/RCBO QuickConnect clamps seem to only allow stranded conductors without end ferrules. Do I understand this correctly, that Hager only allows 1.5-4mm2 solid or stranded without ferrule?
    Hi there,
    correct, the ADS916D allows for 1.5-4mm2 solid or stranded without ferrule.
    If you dont know, you need a 2,5mm (not bigger) flat head screw driver to open the quick connects for stranded wires.
    Other than that, the case makes sure you cannot touch the stripped wire. Given you dont strip it to far.
    I have attached a picture of one of mine.
