Hörmann SupraMatic E, UAP1, spot
    [-] Hörmann SupraMatic E, UAP1, spot
    Hello,
    I've a Hörmann SupraMatic E garage door.
    I've installed the UAP1 and connected it with KNX. I can open / stop / close the door.
    Anyone managed to control the build-in spot ?
    According to the doc, it should be possible, but I've been unable to do it.
    Thanks for any hint.
    The terminal block is at the top right of the switching functions, the three terminal blocks for the bottom left of the status indicators.
    so:
    3 digital outputs to connect:
    High gate 15, 20
    Gate down 17, 20
    Gate lift 23, 20
    2 digital inputs with link:
    Status gate on 01.8, 01.5
    Status gateway to 02.8, 02.5
    Over three binary outputs, I can now turn specifically "high gate", "gate down" and "ventilation (door a crack up)" and two binary inputs I ask specifically the door position "On" / "to" off.
      Hello Redstar,
      Thank you for this detailes reply.
      High gate 15, 20
      Gate down 17, 20
      Gate lift 23, 20
      I managed to control the door and get the status, but I'm unable to control the build-in spot of the SupraMatic.
      According to the doc of the UAP1, it should be possible, any idea about how ?
        here is an extract of the doc I'm referring to.
          If you want external control of the built-in light, you need to activate that function in menu 2 of the main unit.
          Marcus
            Hello Marcus,
            Thanks for the tip.
            I think I've been caught. I think the lamp was working but with the built-in delay the behaviour is masked during this delay.
            Also, the status in the Visu doesn't reflect the actual lamp status, it rather shows the last command.
            Nevertheless, I followed your recommendation and visited menu 2, I changed the factory value (2) to 7. Now I can switch off the lamp via the PB.
            Also, I noticed that when hitting the PB too quick, it doesn't work. Some delay is needed between 2 commands, I've to wait 4-5sec until I hear a clic in the UAP box, before issuing the next command. But that's OK.
            Thank you.
