2xCAT6e + 16/20mm pipe?
    Hello,
    In Sweden we have this product, it's a prewired 16/20mm conduit with 2xCAT6e UTP inside of it.
    I'm looking for the same product in Germany, I have tried to search Idealo and Eibmarkt, but I can't seem to find it.
    Do you have this kind of product in Germany?
    I would appriciate if someone could link a product for me, especially if the do internationel/europe shipping.
    Best regards
    Mani
    This gallery has 1 photos.
    Hi Mani,
    i Build in a CAT7 Duplex Cable in a DN25 Tube and it was a terrible Act. I can't believe if it is really a Double CAT6e. Your Pic Show no Isolation. It seems To be a CAT5. Why do You don't use a Normally Tube like DN25 and buy your CAT separetly ? You Can Save Money too.
    and i don't Know such a Product But i don't know all products good Luck Anyway
    Viele Grüsse Helmut ... der BUSfahrer
    "Wir die Willigen geführt von den Unwissenden, tun das Unmögliche für die Undankbaren. Wir haben so lange so viel mit so wenig getan, dass wir inzwischen in der Lage sind, alles mit nichts zu schaffen."
      Thanks for your answer. The CAT7 i pretty much thicker than CAT6, also have in mind that I'm talking about CAT6e U/UTP, that means it doesn't have any shield on the pairs or the cable itself. It makes the cable even thinner. It's good enough for home installation, no need for the shields.
      In Sweden we have several manufacturers such as PipeLife, PM-Flex and even Schneider Electric (Lexcom/Actassi) that provides 2xCat6 in prewired in either 16mm or 20mm conduit DN16, DN20 i Believe you call it
      /Mani
        Ok, i Text To connect a friend. He work for Schneider Electric and Can give me an product number for Germany
          Dätwyler offers a CAT7 Cable that has an Diameter of 5,8mm over all. You can pull two of them trough the M20 Tubes, but it´s a pain.....
          https://www.deluxecable.de/netzwerk-...mhz/a-1015057/
            Thanks!
            I know it's a pain, thats why I look for pre-wired pipes
            Either way, CAT7 is kind of overkill for my home, I'll go with CAT 6 U/UTP, more than enough with 1 Gbit/s
