HS logic module: Timer
    I'm looking for a basic Timer logic module.
    It should be triggered by a 1 telegram, and run undisturbed until a preset value is expired.
    I've seen the Treppenhauslicht, which works fine, except that it is reset when the input toggles back to 0 (not what I want).
    Is such a module available ? maybe I've overlooked it.
    Thank you
    No, nothing available.
    Why not using Treppenhauslicht, combined with a Filter (1->1, 0 -> nothing)?
      Bad luck. Thank you for the quick reply.
      (I was also looking at your "Wecker" but it's far too complicated for me )
      Maybe, yes, or eventually hammering my own stuff. Hoping to have it ready by Christmas
        I took the Treppenhauslicht module, simply removed the "reset input" paragraph and put back in place the standard header line.
        Works fine. Great timer . Thanks
        Well, afterall, it wasn't a big deal
        Copying the Master is the first step of the learning curve.
