Datenbankproblem nach Update auf v1.10
    [callidomus] Datenbankproblem nach Update auf v1.10
    Hallo Marcus,
    bei dem Update auf die Version 1.10 mit
    callidomus.core update
    callidomus.admin update
    reboot
    ist bei mir wohl was schief gelaufen. Hier der Output vom core-Logfile:
    callidomus:/data/callidomus/local> callidomus.log
    2016-12-07 06:32:58 INFO     Main         Start callidomus 1.10
    2016-12-07 06:32:58 INFO     Main         Branch: stable, Revision: c47c4c3, Timestamp: 201612062017
    2016-12-07 06:32:58 INFO     Scheduler    Start Logics
    2016-12-07 06:32:58 INFO     Main         Init Plugins
    2016-12-07 06:32:58 INFO     Main         cache DB: Problem with '('CREATE TABLE IF NOT EXISTS common (name TEXT PRIMARY KEY UNIQUE NOT NULL, value TEXT);',)': attempt to write a readonly database
    2016-12-07 06:32:58 WARNING  Main         cache DB: Problem with '("SELECT value FROM common WHERE name='version';",)': no such table: common
    2016-12-07 06:32:58 WARNING  Main         cache DB: Problem with '("--############################################################################\n-- Copyright 2016      callidomus                          info@callidomus.com\n-- All Rights Reserved                             https://www.callidomus.com/\n--############################################################################\n\nBEGIN TRANSACTION;\nCREATE TABLE IF NOT EXISTS common (name TEXT PRIMARY KEY UNIQUE NOT NULL, value TEXT);\nCREATE TABLE IF NOT EXISTS state (key INTEGER PRIMARY KEY, ts INTEGER, value TEXT);\nCREATE TABLE IF NOT EXISTS scene (key TEXT    PRIMARY KEY, ts INTEGER, value TEXT);\nCREATE TABLE IF NOT EXISTS num   (key INTEGER PRIMARY KEY, ts INTEGER, value REAL);\nCREATE TABLE IF NOT EXISTS bool  (key INTEGER PRIMARY KEY, ts INTEGER, value INTEGER);\nCREATE TABLE IF NOT EXISTS str   (key INTEGER PRIMARY KEY, ts INTEGER, value TEXT);\nINSERT OR IGNORE INTO common VALUES ('version', '1');\nCOMMIT;\n",)': attempt to write a readonly database
    2016-12-07 06:32:58 ERROR    Main         Unhandled exception: could not run: /mfs/core/lib/cache.sql
    <class 'Exception'>
      File "/mfs/core/bin/cd_core.py", line 654, in <module>
        cd.start()
      File "/mfs/core/bin/cd_core.py", line 247, in start
        self._cache = lib.cache.Cache(self)
      File "/mfs/core/lib/cache.py", line 24, in __init__
        self._execute_file('cache.sql')
      File "/mfs/core/lib/db.py", line 76, in _execute_file
        raise Exception("could not run: {}".format(filepath))
    2016-12-07 06:33:09 INFO     _knx_heartbeat KNX: trying to connect
    2016-12-07 06:34:09 INFO     _knx_heartbeat KNX: trying to connect
    2016-12-07 06:35:09 INFO     _knx_heartbeat KNX: trying to connect
    2016-12-07 06:36:10 INFO     _knx_heartbeat KNX: trying to connect
    Warum die Datenbank plötzlich "read only" ist... keine Ahnung.
    Hardware ist die APU2 mit einer 16 GB mSATA Karte.
    Michael
    Update: Marcus hat das Problem gefixt (hatte mit dem Betriebssystem zu tun) und mein System läuft wieder.
    Danke für die schnelle Hilfe!
    Michael
