Good Evening all,
I am about to install a DRU (www.dru.nl) gas fireplace and I need to find the optimal solution to control the fireplace both with a GIRA Tastsensor3 switch and also via a HS4 installation. The gas fireplace is wired to a GIRA 8 channel switch actor 1037 00.
The fireplace is wired to the switch actor channels 1 to 3 with a four wire setup. Common, 1, 2, 3 (brown, orange, green, blue)
The functions I need to create are:
FIRE on = 1 + 3 + Common connected for 1 second
FIRE level increase = 1 + Common
FIRE level decrease = 3 + Common
FIRE OFF = 1 + 2 + 3 + Common
I can of course achieve this by using FOUR buttons on the Tastsensor3 and within QClient but ideally I would like to be able to solve this with a maximum of three or even two buttons with one being ON / OFF function and then either an additional one of two buttons having the role of Level Increase or Level Decrease or combined.
Does anybody have any great ideas as to achieve the functionality including if need be a logic setup within the HS4.
Many thanks in beforehand.
Kind regards Rolf
Kind regards Rolf
