hab mal auf meinem neuen Wiregate versucht über linknx.xml eine test logik zu schreiben.
der Eib Busmonitor sagt:
2010-07-31 21:48:47.855,A_GroupValue_Write,0.0.17,5/4/0,01,1,DPT_Switch,1.001,0,low,4,T_DATA_XXX_REQ,0
2010-07-31 21:48:47.943,A_GroupValue_Write,0.0.11,5/4/8,01,1,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:48:47.954,A_GroupValue_Write,0.0.11,5/4/8,01,1,DPT_Switch,1.001,0,low,4,T_DATA_XXX_REQ,0
2010-07-31 21:52:01.394,A_GroupValue_Write,0.0.0,3/7/0,00,0,DPT_Switch,1.001,0,low,7,T_DATA_XXX_REQ,0
2010-07-31 21:52:01.398,A_GroupValue_Write,0.0.0,3/7/3,00,0,DPT_Switch,1.001,0,low,7,T_DATA_XXX_REQ,0
2010-07-31 21:52:01.400,A_GroupValue_Write,0.0.11,3/7/3,00,0,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:52:03.229,A_GroupValue_Write,0.0.0,12/0/1,16 8B,67,DPT_Value_Temp,9.001,0,low,7,T_DATA_XXX_REQ, 0
2010-07-31 21:52:03.551,A_GroupValue_Write,0.0.0,12/1/0,0D 46,27,DPT_Value_Temp,9.001,0,low,7,T_DATA_XXX_REQ, 0
2010-07-31 21:52:03.873,A_GroupValue_Write,0.0.0,12/1/1,0D 84,28.24,DPT_Value_Temp,9.001,0,low,7,T_DATA_XXX_R EQ,0
2010-07-31 21:52:04.536,A_GroupValue_Write,0.0.0,12/0/0,17 1A,72.72,DPT_Value_Temp,9.001,0,low,7,T_DATA_XXX_R EQ,0
2010-07-31 21:53:41.522,A_GroupValue_Write,0.0.11,5/4/8,00,0,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:53:42.140,A_GroupValue_Write,0.0.17,5/4/0,01,1,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:53:42.206,A_GroupValue_Write,0.0.11,5/4/8,01,1,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:53:43.126,A_GroupValue_Write,0.0.17,5/4/0,00,0,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:53:43.218,A_GroupValue_Write,0.0.11,5/4/8,00,0,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:53:43.962,A_GroupValue_Write,0.0.17,5/4/0,01,1,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
2010-07-31 21:53:44.643,A_GroupValue_Write,0.0.11,5/4/8,01,1,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0
hätte aber laut linknx.xml das zweite licht auch noch schalten müssen!?
wie kann ich testen ob die .xml wirklich abgefragt wird?
Gruß Volker
Gruß Volker
