Update manuell installieren?
Dieses Thema ist geschlossen.
    [wiregate] Update manuell installieren?
    Hallo.
    Gibt es hier irgendwo ein Paket zum herunterladen, den ich manuell installieren könnte?
    Auf der Update hänge ich mit 5 Pakete
    Reading package lists...
    Building dependency tree...
    Reading state information...
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    5 not fully installed or removed.
    Conf cometvisu-backend (0.4 stable)
    Conf cometvisu-wiregate (0.9.2 stable)
    Conf webmin-wiregate (0.37 stable)
    Conf wg-patch (1.4.0 stable)
    Conf cometvisu-0.8 (0.8.5-4 stable)
    Und nachdem ich auf "Alle verfügbaren Updates" drücke bekomme ich:
    After this operation, 0B of additional disk space will be used.
    Setting up cometvisu-backend (0.4) ...
    Available modules: auth cgi-cometvisu-backend cgi fastcgi proxy rrdtool simple-vhost ssi ssl status
     userdir
    Already enabled modules: cgi-cometvisu-backend cgi
    Enabling cgi-cometvisu-backend: already enabled
    Run /etc/init.d/lighttpd force-reload to enable changes
    Stopping web server: lighttpd.
    Starting web server: lighttpd2017-02-27 19:37:28: (network.c.300) can't bind to port:  80 Address a
    lready in use
     failed!
    dpkg: error processing cometvisu-backend (--configure):
     subprocess post-installation script returned error exit status 1
    dpkg: dependency problems prevent configuration of cometvisu-wiregate:
     cometvisu-wiregate depends on cometvisu-backend; however:
      Package cometvisu-backend is not configured yet.
    dpkg: error processing cometvisu-wiregate (--configure):
     dependency problems - leaving unconfigured
    dpkg: dependency problems prevent configuration of webmin-wiregate:
     webmin-wiregate depends on cometvisu-wiregate; however:
      Package cometvisu-wiregate is not configured yet.
    dpkg: error processing webmin-wiregate (--configure):
    dpkg: dependency problems prevent configuration of wg-patch:
     wg-patch depends on webmin-wiregate (>= 0.3-72); however:
      Package webmin-wiregate is not configured yet.
    dpkg: error processing wg-patch (--configure):
    dpkg: dependency problems prevent configuration of cometvisu-0.8:
     cometvisu-0.8 depends on cometvisu-backend; however:
    dpkg: error processing cometvisu-0.8 (--configure):
    Errors were encountered while processing:
     cometvisu-backend
     cometvisu-wiregate
     webmin-wiregate
     wg-patch
     cometvisu-0.8
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Sieht so aus als ob Update nicht funktioniert. Die Update wurde heute zum ersten Mal - gleich nach Inbetriebnahme - ausgeführt. Auch wenn ich WireGate erst seit ca. Mai 2016 habe bin ich erst jetzt dazu gekommen ;-) . Bevor ich weiter probiere frage ich mal in die Runde ob hierfür bereits eine Lösung gibt. Root ist (noch) nicht aktiviert. Da ich eigentlich noch nix gemacht habe (ausser die Namensvergabe der Sensoren und DNS Einstellung) ist für mich eine komplette Neuinstallation und damit Verlust aller (Konfigurations-)Daten in Ordnung.
    Zuletzt geändert von pitschr; 28.02.2017, 09:58.
    Bitte für individuelle Probleme ein Ticket unter support at wiregate dot de öffnen. Zuvor das Wartungs-VPN anschalten, dann sehen wir uns das an.
    lg
      Danke - hab ein Ticket eröffnet. Thema kann geschlossen werden.
