Neues PlugIn für Dimplex KNX Schnittstelle
    Kam heute als newsletter:
    Carel ETS5 plugin SE new KNX plugin available per ETS5
    We are pleased to announce a new version of Carel KNX plug-in:
    This plug-in is available on KSA (http://ksa.carel.com) under "Software & Support" -> "Connectivity" -> "KNX", here the direct link:
    Plugin and Guide
    https://goo.gl/qq98P3
    Plug-in allows System Integrators to customise the cards with the following part numbers:
    PCOS00KXB0 (BMS Card with cyclical retransmission at two-second intervals)
    PCOS01KXB0 (BMS Card with cyclical retransmission at one-minute intervals)
    PCOS00KXF0 (FieldBUS Card with cyclical retransmission at two-second intervals)
    The plug-in has not lost the flexibility of the previous version, consequently distribution in the form of "project database" has been maintained, allowing address assignment and downloading of the table created with K-Set (XML file).
    Main differences between Carel_plugin_ETS5.knxproj (current solution) and Carel_plugin_ETS5_SE.knxproj (new version) are described in the dedicated communication available here:
    https://goo.gl/r2Oz85
    Habe das neue "SE" Plugin am Wochenende in Betrieb genommen, um das alte ETS4 Plugin im Projekt zu ersetzen. Läuft ohne Probleme. Damit kann die ETS4 virtuelle Maschine nun endlich ausgemustert werden, die ich nur dafür vorhalten musste - hurra!
    Bei mir steht zwar eine Waterkotte Wärmepumpe und keine von Dimplex, aber die Steuerung und die KNX-Karte sind baugleich.
