ETS5 - Cannot programm components
    Shuldigung auf Englisch zu schreiben, mein Deutsch ist nicht so gut.
    I am programming my KNX installation (all components are already a few years old) and I encounter a strange problem.
    I can program my IP gateway, but the moment I want to connect to a component I can't connect.
    My setup:
    - Jung IPS 100 REG - IP gateway
    - K-BUS KI/U 0401.1
    - K-BUS KP/D 30.640.1
    When I do a download all of the IP gateway, it all works. If I do it for the 0401, it hangs on Please press programming button.
    Attached are a few config screenshots.
    Anyone has a magic hint?
    Thanks!
    The IPS 100 REG IP interface needs the newest firmware to be compatible with ETS5.
      Thanks!
      However I also tried with an ETS4 install and I had the same problem.
      But I will try tonight!
        I did not manage to find the update file or how to update this component.
        So I was playing more in ETS4 and I remain on the same issue.
        I checked the bus voltage and physical connections, they are all OK.
