MDT 4ch Dimming akt.
    Hi.
    Currently doing some wiring for some lighting and have a question regarding the MDT 4ch dimming akt.
    Is it OK to pull a 5x1,5mm2 wire for 3ch with different load (electronic transformator, 230v LED and 230v Halogen)?
    Thinking of using common N-neutral to the first junction box and separate the channels from there, or do I also have to pull individual N-neutrals for each channels all the way from the dimming akt.?
    Will be.
    Brown wire, N and PE= electronic transformator
    Black wire, N and PE= 230v LED
    White wire, N and PE= 230v Halogen
    All connected to common fuse.
    -Kaj
    Bump...
