Starting the VPN process seems to fail on my new Wiregate box.
I get following errors in the log file:
Sun Aug 29 20:54:01 2010 OpenVPN 2.1_rc11 i486-pc-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] built on Sep 18 2008
Sun Aug 29 20:54:01 2010 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Sun Aug 29 20:54:01 2010 Cannot open keys/this-server-ca/dh1024.pem for DH parameters: error:02001002:system library:fopen:No such file or directory: error:2006D080:BIO routines:BIO_new_file:no such file
Sun Aug 29 20:54:01 2010 Exiting
Does it mean the key generation at first start-up failed?
I let the box run for more than an hour...
Thanks for your help.
Best regards, Sammy
Best regards, Sammy
