HS logic modules: understanding the overall logic
    Zitat von MatthiasS Beitrag anzeigen
    You mean, the output ist NOT an internal variable?
    mmmmm, no
    That would explain verything.....
    use a fresh internal variable for output and see.....
    and see ....
    I installed .Net 2.0 and the HS monitor.
    I configured the monitor with the HS's IP addr and port
    I enabled the KO gwy in the experte
    but I can't see anything in the monitor.
    Should I fill-in the "key" field in the monitor settings ? I RTFM but haven't seen it.
    It is the last part of the init sequence to read eib group adresses from the bus.
    OK.
    What would be the right way of doing, to avoid this pitfall ?
    Thank you for the lesson !
      Do not select "scan at start" for this eib address.
        Well, "scan at start" was NOT set for this GA
        HS Experte / Kommunikationobjekte / EIB / GA 0/0/1 / Beim Starten abfragen / flag "Ja" not set.
        I tried with the flag "set", same result.
        I would like to know if this is a general HS behaviour (it happens for everyone), or is it specific to my installation (just me).
        Can you help me getting the HS Monitor to run ? It might help me debugging my problems.
        The "settings" menu is greyed-out now, and the system hangs. It was working before, so I guess I made something wrong in the settings.
        Thank you for your patience
          Raymond,
          What you need to do is to allow access. In the "Experte" use the "Absender 1" lien and check the checkbox before it. Assuming yiour network to be 10.0.1.0/255.255.255.0 and you want to allow everybody in that net: IP Address: 10.0.1.0 Netzmaske:255.255.255.0 Schlüsselyou may set a password here to be used in the HS Monitor too then)
          If you want to allow a single PC, set its address, and use 255.255.255.255 as mask
          Then you should check "XML-Struktur der K-Objekte auf Gerät laden". You dio now have the option to allow access to all object read/write via the two checkboxes above this one, or to single objects via checkbox in the Object(KO) parameters. For internal objects you need top assign a virtual group address in the range 100/x to 199/x like 100/1
          After this is done you need to upload the full project including images etc for the XML structure to be uploaded.
          Cheers,
          Gaston
            Great
            It works fine, and with your explanation, I'm (almost) able to understand the doc now
            OK, I'll try it.
            What I'm still missing in ETS & HS Monitor is a kind of filtering mechanism, à la "Network Monitor". Something where you could filter out all traffic related to a GA or PA and concentrate on 1 or 2 addresses in order to focus the troubleshooting to the relevant problem. With Capture & Replay
            I haven't seen this feature in ETS, but maybe such a thing exists ?
            How do you guys troubleshoot a problem in a very big installation ? with hundreds of devices and heavy traffic ?
            Merci Gaston
              If you mark (in Hsmonitor) only those groups that you are interested in, only those will be recorded.
              Same for ETS:
              In group monitor there is a small icon with a hammer on it. It will open a dialog, and third tab ist "filter".
                Same for ETS
                Great tip
                Thank you very much Matthias.
                  Result:
                  variable 1 (input) = 1
                  second variable (output) = 1
                  Impossible to make this thing work
                  Now that I've the HSMonitor up & running, I checked and tested this variable. No way, it is nailed down to 0.
                  Created a new variable, restart, worked first time
                  It beats me.
                  Are there reserved words ? Could it be the variable's name ? I called it NotFirstPass, anything wrong with that ?
                    I cannot imagine that it is the name. But who knows.
                    I often made mistakes, used one variable, copy&pasted the logic and had unexpected behaviour.
                    To be sure, rightclick on the variable in "Kommunikationsobjekte" and check "Verweise". This shows all places where this variable is used.
                      It was used ..... on the same page, .... as an ouput.
                      Due to a bug in my logic module, it was nailed down . Pfiou, the logic is safe
                      check "Verweise" ! !!!
                      Merci
