I'm lost. I have a Homeserver v2.4 running @ customer. Communication with KNX via IP-router. See att. for settings.
The visu works fine (can control, can see status from bus)
When I connect with ETS to iETS on HS, then I can read/write from bus (group addresses). The bus monitor works fine.
But I can't read/program any device on the bus.
Not even read info from a device in ETS.
I can't see the problem. ANyone got a clue/hint for me ?
edit: as can be seen in the attachement, the physical address in iETS settings is 1.2.65. This is actually the physical address of the IP-router. I'm not sure if that's correct !?
Thanx.
Thanx.
