Time switch
    HS/FS Time switch
    Hi.
    Is there any logic block in HS to switch something at a given time?
    If yes... which one?
    Thanks.
    Always, every single day at the same time?
      Yes but with the option to set my own time. I tried the Date+Time block but it fails if the minutes or hours are under 10. I tried the 'leading zeros' block to bring it to 2 digits but didn't seem to work.
        I use module 13401 without issues. I use it for simple time functions. The module can be switched on or off, and the time can be set via a visu or directly in Experte.
        For most time functions I prefer the universal time clock. It is not a module. Settings can only be done via a visu. It works perfectly for daily or weekly switch points.
        Bram
          Thanks!
          I'll look into those options
