[HS/FS] Http command
    Hi
    I want to apologise you that im writing in English but i dont know German.
    I want to get http command from other device (Iphone for ex). I'm typeing adres in webbrowser : hs4adressort/message. I have no idea how can i get this command by HS. When i evaluate adress it take some second to refuse error so command reaches the server. I attached picutre wchich show my configurations of UDP/TCP/HTTP.
    Ich möchte HTTP-Befehl von anderen Geräten (Iphone für ex) bekommen. Ich schreibe adres in webbrowser ein: hs4adressort / message. Ich habe keine Ahnung, wie kann ich diesen Befehl von HS bekommen? Wenn ich die Adresse auswerfe, dauert es eine Sekunde, um den Fehler zu verweigern, so dass der Befehl den Server erreicht. Ich habe picutre angeschaut, die meine Konfigurationen von UDP / TCP / HTTP zeigt.
    This gallery has 1 photos.
    Zuletzt geändert von JSobczak; 27.09.2017, 14:54.
    Hello J!
    Welcome to the forum.
    Guess you know how to use Google Translate :-) You will need it to fully understand this Lexicon page: https://redaktion.knx-user-forum.de/...-ip-telegramm/
    It has an example of how to set up what apparently you want to achieve. The pictures alone will already give a good hint at how to go about it.
    Bram
      Hello Bram.
      Thank you for quick response. You are right, but i noticed that Google Transalte translate german to english very well, so i tried to be a little bit helpfull to German friends.
      At first sight it looks like a tip wchich should help to solve my problem. Ill check this and show results.
      Im very grateful for your help.
      Best regards
      Jacob
