Use of Argus 220 brightness object
    I have an Argus 220 (Merten) movement sensor in the hallway which is used to switch on the lights when somebody enters the hallway.
    Can I use a brightness object of this movement sensor to switch on the lights in another room?
    At the moment I've configured an actor output with an AND function. When there is movement in that other room (this is only detected by a binary actor without any brightness object) AND the brightness object of the Argus 220 is ON, the actor output should be switched ON.
    Although this works, I have trouble when the lux value goes up or down (e.g. a cloud is in front of the sun). The lights are switched ON or OFF within minutes. I cannot figure out to build in a margin.
    Would this be feasible with the movement sensor and the binary actor?
    Regards -- Ivan
    So whenever the the brightness is around 500 lux, the Argus 220 movement detector sends repeatedly ON, OFF, ON, OFF, ON, ... commands. Can this be solved?
    My configuration:
    Block 2 general
    - Locking function: disabled
    - Operation mode: normal operation
    Movement sensor
    - Extended Settings: disabled
    - Sensitivity: high
    - Range adjustable: via parameters
    - Range: 100%
    Brightness
    - Movement detection is: brightness-dependent
    - Brightness threshold adjustable: via parameters
    - Overwrite brightness threshold during download: enabled
    - Brightness threshold (3-1000 lux): 500
    - Brightness threshold object: disabled
    - Brightness object 1 bit: send inverted
    - Always-dark object: disabled
    Telegrams
    - Action at start of movement: send immediately
    - When movement time elapsed: send after staircase timer time has elpased
    - Output object 1: disabled
    - Output object 2: disabled
    - Output object 3: disabled
    - Output object 4: disabled
    - Pause between two telegrams: 5
    Times
    - Via movement, time is: retriggerable
    - Staircase timer adjstable: via parameters
    - Overwriting staircase timer during download: enabled
    - Self-adjusting staircase timer: disabled
    - Time factor staircase timer object: disabled
    - Time base for staircase timer: 1 min
    - Time factor for staircase timer: 25
