Projektdatei hat keine gültige Signatur / Project file has no valid siganture
    Hello everybody,
    I have a problem with import database file (product file) for Gira G1 to my ETS5. I have ETS 5.5.2 Proffesional version. I tried import it with the newest version of ETS (DEMO) but with the same result. If I want to import it, there is an error with text: "Project file has no valid siganture"
    Thanks a lot
    This gallery has 1 photos.
    Just tried it with ETS 5.5.4 and the file from https://www.gira.de/data3/20679400.zip with no problem.
    I recommend that you open a support ticket in your my.knx.org account.
    Klaus
      Hi. That's not a project file but a product application file - You need to load that into the Catalog in ETS, not as a project!
        Klaus, thanks, I´m going to write to support.
        trollvottel, of course, I tried it import to catalogue, not to projects..
          How about update to current ETS Version, will be most likely the first answer from support. (Ok, just saw that you testet it with the demo version)
          Regards Florian
            Oh ok. Then the error message indeed looks like a bug - At least the message itself talks about project, not application...
              Problem solved! It wasn´t about the current version of ETS. Problem is in the regional language options and location settings in Windows. I changed it from Slovak and Slovakia to the Germany, or English and after this the import was successfull.
