Issues with Busch Control Touch
    Hi All,
    Apologies for typing in English as I dont know German.
    I have just started using Control Touch and have few questions and I hope you can answer it for me:
    1. Can the control touch be used as an Ip interface? I.e can i program ETS via control touch like you can do with the X1?
    2.Data logger: It says it will save data for one year! Now if there is a power cut will data be lost and will it start fresh? or will there be a just a gap in the data for the time there was a power cut as the data is actually stored in the portal?
    3. Can the data be transferred to say an SD card?
    4. I am using a Gira 5142 thermostat and i am just not able to do the set point change! The example shown in the manual uses a prion which has a" request " & " confirm" setpoint.But the gira doesnt. Any one knows how to fix this please?
    5. The trigger functions says you can use " AND" / "Or" functions. But what if i want to use a say other comman logic functions like comparter or even simple things like filter/gate functionalities.
    Any help would be great! Thanks for your time
    Kind Regards,
    Akash
    Any help guys? Please?
      1. Can the control touch be used as an Ip interface? (YES)
      2. I.e can i program ETS via control touch like you can do with the X1? (I don’t know.)
      3. Data logger: It says it will save data for one year! (3 YEARS) Now if there is a power cut will data be lost and will it start fresh? (NO) or will there be a just a gap in the data for the time there was a power cut (YES) as the data is actually stored in the portal? (Is not stored in the cloud)
      4. Can the data be transferred to say an SD card? (Not yet)
      5. I am using a Gira 5142 thermostat and i am just not able to do the set point change! The example shown in the manual uses a prion which has a" request " & " confirm" setpoint.But the gira doesnt. Any one knows how to fix this please? (You can also use a normal temperatur value 2-byte to change the temperatur)
      6. The trigger functions says you can use " AND" / "Or" functions. But what if i want to use a say other comman logic functions like comparter or even simple things like filter/gate functionalities. (You have to build a script)
      Best regards,
      Peter (PM)
        Thanks Peter!
