- √ - Illuminating only at certain hours
    HS/FS - √ - Illuminating only at certain hours
    I've already used the UZSU for controlling events, but sofar, I haven't done it in conjunction with other conditions.
    I want to allow the switch-on of a lamp only at certain hours, i.e. between 18h00 and 08h00.
    I guess I've to use an AND gate with input from the switch AND some input from the UZSU but have no idea about how to do it.
    Thank you for your help
    You can define one UZSU "light permission". Add two command: "light permission ON" and "light permission OFF". The two commands will switch an internal KO ON and OFF. This internal object will be ANDed
      Hi Matthias,
      Thank you for the quick reply, but pfiouuu, I'm not going to switch on that lamp today
      Could you have a look at the picture below and tell me if it's right ?
      Mmm, don't see how to do this. How can I fetch this iKO and use it in my AND gate ?
      It's not clear to me, what has to be done in the Experte and what has to be done on the client (I'm still plagued with this problem, just to make my life a bit more difficult )
        No, not this way
        On "Kommunikationsobjekte", select "Internal" tab an add one new object. Let's call it "WWSLT" with type of binary - 1bit.
        WWSLT means "warichet will switch light today"
        The two comands in your UZSU
        Permission ON: set WWSLT to 1
        Permission OFF: Set WWSLT to 0
        In your AND gatter you cann add WWSLT ....
          I love your strong sense of humour ....
          WWSLT is still at 0 The damn thing is beating me 4-0
          Also, I'm a bit confused with the UZSU as there are 2 places to enter data
          1) under EIB-Steuerung / UZSU
          2) under Oberfläche / Menü
          Never give up, persist !
            USZU
            Under Experte, you have to design what actions are possible.
            Under Oberfläche, you select these predefined actions and select the times when they will be executed.
            I won't give up, don't worry
              The damn thing is still beating me, but 4-1 now.
              French characters are not allowed in the UZSU (é, è etc)
              So I couldn't see my items (there was a question mark instead of the title)
                WWSLT = 1
                I made the classical mistake by putting times i.e. 18:00 till 08:00
                But the clock has to pass over the time limit to make it active, so I've put the time 5 min ahead to allow for a re-boot and bingo
                Now I've to add a timer to keep the lamps on for 5min.
                Thank you Matthias
