Hager IOT Controller
    Hi!
    has someone here tried to setup more than one iphone for geofencing true IFTTT ?
    Im also having problems with the sonos funktions, they are extremly delayed when sending knx commands or using dashbord, what could that be?
    /p
    the Sonos Problems are The same in my Installation. I also have a Problem Tod Update The new version 1.6.4. I symply cannnot reach/Push the „update Button“.
    Has anyone a Solution?
    THX
    Carlo
      Regarding IFTTT: Unfortunately you can link your Hager IoT device only to one IFTTT account (= one iPhone). I hope that Hager allows us mutliple accounts (for each person in the household), but I dont think we will get that feature in the near future.
        Carlo, i have the latest update installed, did not have the problem you are having.
        I hope the people at Hager reads this, becuse they are major issues.
        /p
          I think that's not quite correct. For example, we use ifttt to turn on the lights in the driveway as we approach the house. Everyone in our house has a ifttt account and each one is linked to the same HAGER IOT account. So 1 Hager account and x ifttt accounts.
            Ich glaube ich weiß was du meinst, wenn man den Ansatz von IFTTT macht und nicht von Hager, müsste es eigentlich klappen - das muss ich demnächst mal austesten. Danke für den Tipp.
            Kannst du vielleicht sagen wie zuverlässig IFTTT bei dir läuft? Habe es aktuell überwiegend mit Philips Hue um Einsatz und gefühlt funktionieren die Applets von 100 mal nur 95 mal, die anderen 5 werden nicht korrekt erkannt bzw laufen ins Leere.
              Dual ifttt accounts seams to work, but i am still having major problems with the sonos function, commands are working but the delay is 10s++ time
              /p
                /p
                I had the same problem with the BAB App Module and Bose with delays of 5-10 seconds. I've heard that the ISE Module works well with Sonos, but it's quite expensive.
                  Gah, the problem is still there, im using apple airport extreme with static ip’s on all sonos devices locked true macadresses. Hager has no clue what could be the problem. Anyone? /p
                    With the new update 1.6.6 the Sonos is now working without delays for me!
