Converting a Visu
    Converting a Visu
    I've developped my Visu as Gira1024. On the EloTouch, it doesn't look fine (black border).
    What is the most easy way to convert it to Gira1024V ?
    I've read the posts about changing resolution, but in this particular case, I guess the icons remain unchanged ?
    Thank you for any hint.
    Unfortunately there is no way without "Sehnenscheidentzündung" (short translation: means pain)
    Postpone this question for 3-6 months, then there might be a satisfying answer, no conversion but easy - and without resolution-dependency
    It currently looks good, that I'm right with this assumption Although still not guaranteed..
    Makki
    -> Bitte KEINE PNs!
