Gira QuadClient - Reconnect?
    I'm getting regularly these "reconnect" messages on the screen of my Gira QuadClient. (image 1) Sometimes this takes a few minutes, but most of the time, it can be more than an hour before this resolves itself.
    At the time of this onscreen message, I can't ping the homeserver, but since I can't remotely login to the server with SSH, I have no idea what is going on. Looks to me like a software issue, as it automatically goes away after a while.
    Anyone have an idea?
    This gallery has 1 photos.
    I'm also getting these errors on the debug page of the HS, maybe this helps? As I can't SSH into the server, I can't go trough these files to find out what is going on :/
    The reconnect error is coming more frequent today, almost unworkable
      The HS was located in our garage. I moved it to another room in my house, removed the top lid and looked closely at the motherboard. Some of the capacitors are starting to bulge, so I think the are about to go kaputt...
      Strange thing is, now that the HS is in the other room, I haven't got any reconnect errors anymore. So I assume it could be 2 things:
      - bad network connection in the garage
      - overheating of the HS with the lid closed (maybe coupled with the bad capacitors?)
      If it comes to it, I'm going to replace them, but only if it's abolutely needed, as soldering on a motherboard isn't something I do on a daily basis. But if you need to replace something on a MB, the capacitors are one of the least difficult components due to their size
      Will keep you updated, any input from other people with similar problems is allways appreciated
