Icould need some advice regarding a temp control with PID controller.
The situation:
- a room with radiator and fancoil
- I need to control the temperature of the air inlet from the fancoil.
- the temp. sensor is directly behind the heat sourse, so temp. changes quickly
- controller of Arcus-EDS didn't do the job (lot of over/undershoot, and never stable, keeps swinging)
- now I have disabled this controller and use the PID controller in the H/S
- All variables (p,i,d,cycle) are changable via visu
the result (see graph from QC) is better, but not satisfying. I would like to know what could be better settings than I have now. I already tried some combinations, but maybe somebody here has more experience with PID and heating.
another question about this: does it matter waht value I enter in the input of the PID controller ? I mean: When I enter a value "1" in the nachstelzeit of the PID module, and then change it via an object, does it actualy change, or do I have to put a'" 0" in it as default value. So, is it only a default value that will be overwriten ?
The situation:
