> There is no lock mechanism.
Thank you.
I've to look somewhere else.
> If you can access the Debug-Page but not transmit new projectdata, reboot the server by using the powerswitch
OK, thanks. That's usually what I do, when I don't know what to do ;-)
> What is your problem at all?
Well.... a bit crazy, that's why I didn't publish. You asked for it, here goes.
From within my LAN, I can reach the HS with different accounts and syntax, no problem. This rules out many potential causes.
I've no access to/from the outside world, this hints towards dyndns, I checked it, looks normal.
I guess I've to work a bit, anyway, it's not a HS or KNX issue.
PS: not so long ago, I've changed my IP architecture, from a 10.x.x.x to a more reasonable 192.168.x.x, I still find sequels in every corner. Migration effort was quite under-estimated
