If you are sure that you are downloading the right application program in the right device, and if the error can be reproduced, then closer details are needed, from the ETS log files. You should create a support ticket in your KNX account for help.
"Writing to a memory block failed" just mostly means that ETS tries to write something in the device's memory and the device does not respond, it responds with an error, some verification goes wrong...
