PB as input for a logic module
    I would like to use a PB as input for a logic module.
    So far, I've used GA as input, no problem.
    The help says (yes, I read the help )
    Eine Eingangs-Box kann folgende Elemente enthalten:
    • Kommunikationsobjekte
    • Konnektoren
    Although I can see the KO in ETS (i.e. button #2 of a 4 gang), I've no idea on how to make it visible for the HS. I guess "export" works only for GA.
    Thank you for your help
    What does "PB" mean?
      PB --> PushButton.
      A "Kommunikationsobjekt" has to be to connect to a GroupAdress,
      A "Konnektor" is an (HS) internal connector for connecting Logic-Modules together - over more than 1 working-sheet.
      So you can use 1 "Konnektor" on different (Logic ! )- working-sheets.
      So you have to export the GroupAddress from the ETS (and there from the KO) to the HS-Experte.
        Zitat von EIB-Freak Beitrag anzeigen
        A "Kommunikationsobjekt" has to be to connect to a GroupAdress.
        OK. Thank you.
        (the Help could have been a little more explicit)
          Such in the ETS, every KO you will use, it have to be a Group Adress - also in the HS. so that is not different.
            Mmmm, yes, you are right.
            I should have known better
