Gira HomeServer Query trouble
    Good morning,
    I have a problem with Gira Homeserver 4. On two applications homeservers doesn't "Query during starting" after reboot or Transfer project. I use Experte 4.4. I tried use Experte 4.5 and it doesn't take results. I'm ticking the box "Query during starting" and i transfer project with correct button (NO ...without scan). The retentive objects works fine and after restart HomeServer sends values to the bus, but doesn't read from other devices.
    I noticed once if i Transfered the backup of project from a month ago the Homeserver Query correctly and then if i Transfered current project he query once, after another transfers it doesn't work again. I don't have idea what can go wrong. On another applications i never have this problem.
    This applications was started on FW 4.2. When I transfered firmware 4.2 for experiment. And it helps. I have to use firmware 4.2 for correct work of query during starting.
    Can someone help me, Please ?
    I make screen from debug list where on firmware scan doesn't work (pic1), works on firmware 4.2 (pic2) - it says the scan error, but it works fine , and other project application whose started and works on firmware 4.5
    This gallery has 3 photos.
    Zuletzt geändert von Patryk Lojewski; 27.06.2018, 15:26.
