Data type: EIS6 without commas
    HS/FS Data type: EIS6 without commas
    I want to display some info about a water pit in the HS Visu.
    So far, I'm able to display the actual water height (16 bit EIS5) in a dynamic text box. Looks OK.
    I've build a dynamic icon to show the raw status of the pit, in % (i.e. 0, 25, 50, 75, 100). I want this icon to be driven by an integer representing a %.
    To do so, I divide the actual height by the max height and put the result in a 8 bit (0-100%/EIS6) but I still have a result with a number after the comma, i.e. 87,5
    How can I get a pure integer, from 0 to 100 ? i.e. 87 (instead of 87,5)
    Thank you for any hint
    PS: Until now, I thought integers didn't have commas
    I use this dynamischen Text.
    Gerald Düthorn
      Hi Gerald,
      Thank you for taking the time to reply.
      If I understand your example well, it is to display an integer in the Visu.
      My problem is very similar, but it is rather to "format" an integer in a iKO.
      I don't know which option I should select below... any idea ?
