How to fix filter-table problem with Gira X1?
    First of all, sorry for my english.
    I have a KNX setup with three TP-lines (1.0.0, 2.0.0, 3.0.0) connected to one IP backbone.
    Currently I have connected my Gira X1 via TP as 1.0.2 in the 1.0.0-line. Since the Gira X1 is configured via GPA, ETS has no knowledge about the group-addresses used by Gira X1 which have to be passed from other lines. As a result some group-address-messages from the 2.0.0 and 3.0.0 lines are not passed through to the 1.0.0 line and to Gira X1 by the filter-tables.
    I considered using the VisuDummy ETS-app. But GPA has no export function of the group-addresses used, or I cannot find it? Another option is to use the ETS options of the X1-device-object. But there seems to be no automatic way of filling the used group-addresses again.
    There is no export from X1, usually you start out with an ETS project and connect the dummy directly. So you should know, which GAs you intend to use.
    Regards Florian
