- √ - Looking for a logic module
    I'm looking for a logic module that would "encode" the ouput value, based on an input.
    Example: 4 inputs, 1 output (integer)
    If input 1 is active, the ouput value would be 1
    If input 2 is active, the ouput value would be 2
    etc
    Is such a module available ?
    Thanks
    Yes, but with 2 instead of 4 Inputs, but this should be no problem for you to edit in an own module.
    The name is: "Nummer des Eingangs" and could be found in "Auswahlschalter".
    Gruss aus Radevormwald
    Michel
      Thank you very much for this super fast reply.
