Homeserver Quad Client Transfer problem
    Sorry for writing in English
    HS 4, Expert 4.4
    I have made changes in QC Config, run check project and have transferred modified project to HS. Expert reported no problems with transfer. I go to Client QC and it still shows the old version of QC. I have done transfer data and transfer data with delete retentive memory. Still the same problem. Any help would be appreciated
    Have you tried to reconnect your profile in QC on your Appliances? Maybe qc didnt pull the newest version from the HS!?!
    Mit freundlichen Grüßen,
    Martin W.
    Dipl.-Wirtsch.-Ing. (FH)
    Staatl. gepr. Elektrotechniker
      thank you for advice but that is not the case. I have tried and reconnected on PC, Android App, Control 9. same problem
        Did you make any changes in: QC-Config => Projekt => Allgemeines => Designs ? Only the ones which are marked here are being transfered.
        And of course you have to select: Projekteinstellungen => Oberfläche "QC Daten an Homeserver übertragen"
          thank you. i have done all that before. I figured that I need to check "data, Images, + voice mails" for Quad changes to be transferred
