import empty GA's in expert
    I am trying to import all (more that 500) GA's that where created by Aritech interface into HS Experte via OPC file.
    But most of them are empty, so they are not imported by HS (or exported by ETS4 ??)
    EDIT: when I look in the OPC file that was exported by ETS4, the GA's are not there, so they are not exported by ETS4
    Anybody has done this before, or has a solutution ?
    grusse,
    Mike van der Hulst
    Domoticom (NL)
    use a dummy application and link one of its objects to all the empty GA.
    eg gira provides such applications. (look for "dummy" in the gira product database).
    objects of all length/DPTs are available.
    you could also link any random object and delete the links after opc-export, but you may run into similar problems later. also you cant link that many addresses to one normal object...
      ok, that solved my problem. Many thanx!!
      grusse,
      Mike van der Hulst
      Domoticom (NL)
