What is the best way to display a detailed status ?
    What would be the best way to segregate bits in a status byte, in order to display a detailed status in the Visu ?
    I first started with "dynamic text", but I end up with too many combinations, hence too many definitions, and there is always an unforseen case that comes along.
    i.e. 32 for bit 5, 64 for bit 6 plus all the least significant bits
    I thought using 8 "AND" to isolate individual bits and display accordingly.
    One benefit: no unforseen values can pop-up.
    But this would require 8 variables per status byte.
    Maybe another method ?
    Any recommendation ? or "good practice" hint ?
    Thank you.
    Easiest way:
    - use a 1byte to 8-bit converter
    - there is logic module from bytefactory, called "conditional text"
    - use it twice
    - define text tags for every bit (0-3) and 4 to 7
    - you will get one 14byte text for 0 to 3
    - and one for 4 to 7
    If you connect the two modules ("Ergebnis" to "Vorheriger Text"), you will have in the end one dynamic text.
    http://www.kuehn-clan.de/eib/homeser...BedingungsText
      Hi Matthias,
      Thank you for the quick reply
      I didn't say it, but I want to have the several status text, one above the other (instead of one long sentence), close to the icon. But I guess I can do it with the suggested module.
