- √ - Fehler bei Update auf PL27
Dieses Thema ist geschlossen.
    [wiregate] - √ - Fehler bei Update auf PL27
    Hallo Makki,
    ich bekomme beim Updaten folgende Fehlermeldung :
    Reading package lists...Building dependency tree...Reading state information...The following packages have been kept back: librrds-perl0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.4 not fully installed or removed.After this operation, 0B of additional disk space will be used.Setting up eibd-server (0.0.4+nmu16) ...*** Restarting EIB/KNX daemon eibd *** eibd: Autodetecting Interface .Unable to read BCU address table - retrying 1 - retrying 2 .. - FAILED on usb (url ) (size expected) ! failed!dpkg: error processing eibd-server (--configure): subprocess post-installation script returned error exit status 2dpkg: dependency problems prevent configuration of eibd-config-wg: eibd-config-wg depends on eibd-server (>= 0.0.4+nmu16); however: Package eibd-server is not configured yet.dpkg: error processing eibd-config-wg (--configure): dependency problems - leaving unconfigureddpkg: dependency problems prevent configuration of wg-patch: wg-patch depends on eibd-config-wg; however: Package eibd-config-wg is not configured yet.dpkg: error processing wg-patch (--configure): dependency problems - leaving unconfigureddpkg: dependency problems prevent configuration of wiregated: wiregated depends on wg-patch; however: Package wg-patch is not configured yet. wiregated depends on eibd-server; however: Package eibd-server is not configured yet.dpkg: error processing wiregated (--configure): dependency problems - leaving unconfiguredErrors were encountered while processing: eibd-server eibd-config-wg wg-patch wiregatedE: Sub-process /usr/bin/dpkg returned an error code (1)
    Was kann das sein, bzw was muss ich machen ?Gruß ManuelPS Wiregate119
    Das Problem versteckt sich zwar gut, aber liegt hier:
    Es ist USB als KNX-Schnittstelle eingestellt aber keine solche dran; das war vielleicht schon länger so und kommt jetzt nur blöd mit dem Update zusammen..
    Also anstecken oder eine andere einstellen, ein erneuter Klick auf Updates (oder "apt-get install") sollte es dann auflösen
    Makki
    -> Bitte KEINE PNs!
      Hallo Makki,
      danke für deinen schnellen service. Hattest recht, ich habe die Schnittstelle gebraucht und noch nicht wieder angesteckt.
      Super Danke
      Ein Problem habe ich noch :
      librrds-perl
      Danke Manuel
        Das ist nur unwichtiges gequängel, ich habs mal repariert aber die wird eh für nichts verwendet (Usache ist das "angepasste" rrdtool für die CometVisu, ich schreibs mir auf..)
        Aber für was braucht man die USB-SS? Tunneling am WG aktivieren und ETS hernehmen, fertig (?)
        Makki
        -> Bitte KEINE PNs!
          Hallo Makki,
          nachdem bereits mit Patchlevel 26 eine Fehlermeldung bezüglich collectd angezeigt wurde, bin ich etwas beunruhigt, da collectd sich nun auch bei Patchlevel 27 wieder meldet:
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          1 not fully installed or removed.
          Setting up collectd (4.4.2-3+lenny1) ...
          debconf: unable to initialize frontend: Dialog
          debconf: (TERM is not set, so the dialog frontend is not usable.)
          debconf: falling back to frontend: Readline
          Starting statistics collection and monitoring daemon: collectdinvoke-rc.d: initscript collectd, act
          ion "start" failed.
          dpkg: error processing collectd (--configure):
          subprocess post-installation script returned error exit status 1
          collectd
          Hast du eine Ahnung was hier passiert (oder eben nicht)?
          Gruss, Felix
            Hoi Felix
            Hatte ich auch.
            Der collectd stoppt nicht und lässt sich daher nicht upgraden.
            Wenn ich das richtig verstanden hab.
            Makki wird Dir sicher sagen wie's einfach zu richten ist.
            Ist aber nix schlimmes.
            Grüsse Bodo
              Kuckt mal hier zur collecd-Meldung: https://knx-user-forum.de/145555-post16.html.
              Evt. trifft das Problem auch bei Dir zu. Einfach PN an Makki mit der WG-Nummer und Fernwartung auf, dann wird es für Dich i.O. gebracht.
                danke vielmals. Mit den Hinweisen hat sich dieses Problem nun auch gelöst. Alles läuft bestens!
                Gruss, Felix
                  Fein . Ich mach dann mal einen Haken an diesen Thread.
                    Hallo Makki,
                    warum ich eine USB-Schnittstelle verwendet habe ich der, dass ich das Wiregate nur an einem Testaufbau betreibe.
                    Gruß Manuel
