Webabfrage and https prefix
    HS/FS Webabfrage and https prefix
    I've a problem with a Webabfrage to a Google Group RSS feed.
    This Webabfrage worked for a long time.
    I used this url
    HTML-Code:
    http://groups.google.fr/group/domotique-EIB/feed/rss_v2_0_msgs.xml
    Google has changed from http to https prefix, and the url now points to groups.google.com (instead of .fr)
    I've amended the definition in the Experte as follows
    Daten: groups.google.com (instead of .fr)
    Senden: /domotique-eib/feed/rss_v2_0_msgs.xml (unchanged)
    download/reboot, trigger the Webabfrage
    Nothing happens, i.e. nothing to be seen in Debug Event (empty), not even the beloved "Work 0" which I get so often
    When I type the complete path of new url in the browser, i.e.
    HTML-Code:
    http://groups.google.com/group/domotique-eib/feed/rss_v2_0_msgs.xml
    or
    HTML-Code:
    https://groups.google.com/group/domotique-eib/feed/rss_v2_0_msgs.xml
    it works fine, I see the XML page in the browser, so I'm sure about the syntax
    I'm unsure about the https prefix, I cannot enter it in the Experte as it is not part of the data.
    I did use the SuFu
    Any hint, please ?
    httpS protocol is not possible with HS at the moment.
      Thank you for the quick reply.
      I was puzzled by the fact that, when entering the old syntax (http) in the browser, it works ! So I guess it is somewhere on the return path that things go wrong
