Problem with MT701V2.0
    KNX/EIB Problem with MT701V2.0
    I have a MT701V2 Merten entered into the alarm with flashing white screen. Already turned off the power and the bus, I reset and still the same ... anyone can help me! "
    thanks,
    manel
    Did you already try to send the program data again?
      Please try the following: Start the ETS-Plugin, start download. After a while you'll get the information that the download isn't possible. Answer with "yes" to start the firmware-download.
      Furthermore you should install the latest plugin, where this problem is solved.
      Regards,
      Frodo
        yes i´have
