- √ - Error bei Update auf PL27
Dieses Thema ist geschlossen.
    [wiregate] - √ - Error bei Update auf PL27
    als ich gestern das Update auf PL27 durchführen wollte, kamen folgende Meldungen in der WebUI:
    Reading package lists...
    Building dependency tree...
    Reading state information...
    The following NEW packages will be installed:
      libconfig-tiny-perl libjson-xs-perl
    The following packages will be upgraded:
      eibd-clients eibd-config-wg eibd-server libeibclient-dev libeibclient0
      librrd-cgi-image-perl webmin-wiregate wg-baseweb wg-patch wiregated
    10 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
    Need to get 2302kB of archives.
    After this operation, 270kB of additional disk space will be used.
    Get:1 http://repo.wiregate.de wiregate-0.1/main wg-baseweb 0.3-5 [49.4kB]
    Get:2 http://repo.wiregate.de wiregate-0.1/main librrd-cgi-image-perl 0.03-1 [12.3kB]
    Get:3 http://repo.wiregate.de wiregate-0.1/main libjson-xs-perl 2.01-1+b1 [81.1kB]
    Get:4 http://repo.wiregate.de wiregate-0.1/main libconfig-tiny-perl 2.12-1 [13.7kB]
    Get:5 http://repo.wiregate.de wiregate-0.1/main webmin-wiregate 0.3-38 [1657kB]
    Get:6 http://repo.wiregate.de wiregate-0.1/main eibd-server 0.0.4+nmu16 [302kB]
    Get:7 http://repo.wiregate.de wiregate-0.1/main eibd-config-wg 0.2-11 [4112B]
    Get:8 http://repo.wiregate.de wiregate-0.1/main libeibclient-dev 0.0.4+nmu16 [54.9kB]
    Get:9 http://repo.wiregate.de wiregate-0.1/main libeibclient0 0.0.4+nmu16 [18.1kB]
    Get:10 http://repo.wiregate.de wiregate-0.1/main eibd-clients 0.0.4+nmu17 [67.9kB]
    Get:11 http://repo.wiregate.de wiregate-0.1/main wiregated 0.9-38 [29.4kB]
    Get:12 http://repo.wiregate.de wiregate-0.1/main wg-patch 0.0.27-2 [12.0kB]
    debconf: delaying package configuration, since apt-utils is not installed
    Fetched 2302kB in 7s (329kB/s)
    (Reading database ... 51549 files and directories currently installed.)
    Preparing to replace wg-baseweb 0.3-4 (using .../wg-baseweb_0.3-5_all.deb) ...
    Unpacking replacement wg-baseweb ...
    Preparing to replace librrd-cgi-image-perl 0.02-1 (using .../librrd-cgi-image-perl_0.03-1_all.deb)
    Unpacking replacement librrd-cgi-image-perl ...
    Selecting previously deselected package libjson-xs-perl.
    Unpacking libjson-xs-perl (from .../libjson-xs-perl_2.01-1+b1_i386.deb) ...
    Selecting previously deselected package libconfig-tiny-perl.
    Unpacking libconfig-tiny-perl (from .../libconfig-tiny-perl_2.12-1_all.deb) ...
    Preparing to replace webmin-wiregate 0.3-34 (using .../webmin-wiregate_0.3-38_all.deb) ...
    Unpacking replacement webmin-wiregate ...
    Preparing to replace eibd-server 0.0.4+nmu15 (using .../eibd-server_0.0.4+nmu16_i386.deb) ...
    Unpacking replacement eibd-server ...
    Preparing to replace eibd-config-wg 0.2-10 (using .../eibd-config-wg_0.2-11_all.deb) ...
    Unpacking replacement eibd-config-wg ...
    Preparing to replace libeibclient-dev 0.0.4+nmu12 (using .../libeibclient-dev_0.0.4+nmu16_i386.deb)
    Unpacking replacement libeibclient-dev ...
    Preparing to replace libeibclient0 0.0.4+nmu12 (using .../libeibclient0_0.0.4+nmu16_i386.deb) ...
    Unpacking replacement libeibclient0 ...
    Preparing to replace eibd-clients 0.0.4+nmu14 (using .../eibd-clients_0.0.4+nmu17_i386.deb) ...
    Unpacking replacement eibd-clients ...
    Preparing to replace wiregated 0.9-36 (using .../wiregated_0.9-38_all.deb) ...
    Unpacking replacement wiregated ...
    Preparing to replace wg-patch 0.0.26 (using .../wg-patch_0.0.27-2_all.deb) ...
    Unpacking replacement wg-patch ...
    Processing triggers for man-db ...
    Setting up wg-baseweb (0.3-5) ...
    Setting up librrd-cgi-image-perl (0.03-1) ...
    Setting up libjson-xs-perl (2.01-1+b1) ...
    Setting up libconfig-tiny-perl (2.12-1) ...
    Setting up webmin-wiregate (0.3-38) ...
    Setting up eibd-server (0.0.4+nmu16) ...
    *** Restarting EIB/KNX daemon eibd
     failed!
    dpkg: error processing eibd-server (--configure):
     subprocess post-installation script returned error exit status 1
    dpkg: dependency problems prevent configuration of eibd-config-wg:
     eibd-config-wg depends on eibd-server (>= 0.0.4+nmu16); however:
      Package eibd-server is not configured yet.
    dpkg: error processing eibd-config-wg (--configure):
     dependency problems - leaving unconfigured
    Setting up libeibclient0 (0.0.4+nmu16) ...
    Setting up libeibclient-dev (0.0.4+nmu16) ...
    Setting up eibd-clients (0.0.4+nmu17) ...
    dpkg: dependency problems prevent configuration of wg-patch:
     wg-patch depends on eibd-config-wg; however:
      Package eibd-config-wg is not configured yet.
    dpkg: error processing wg-patch (--configure):
    dpkg: dependency problems prevent configuration of wiregated:
     wiregated depends on wg-patch; however:
      Package wg-patch is not configured yet.
     wiregated depends on eibd-server; however:
    dpkg: error processing wiregated (--configure):
    Errors were encountered while processing:
     eibd-server
     eibd-config-wg
     wg-patch
     wiregated
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Angezeigt wird jetzt aber, dass PL27 installiert ist. Ist das ganze evt. gar kein Problem?
    Das TP-UART war glaube ich während des Updates nicht angesteckt, kann das eine Ursache sein?
    Danke
    Micha
    Das wird daran gelegen haben..
    Einfach die Schnittstelle anstecken bzw. eine andere gültige Konfiguration eintragen und nochmal auf "Alle Updates ..." klicken, dann sollte sich das selber flicken.
    Makki
    -> Bitte KEINE PNs!
      Makki
      Danke, genau so hat es funktioniert!
      Micha
        Hoi
        Ich will auch, hatte beim Update folgende Meldung:
        Setting up wiregated (0.9-38) ...
        *** Restarting WireGate daemon wiregated
        *** Starting WireGate daemon: wiregated
        /etc/init.d/wiregated: line 38: 19646 Terminated              start-stop-daemon --start --quiet --p
        idfile $PIDFILE --exec $DAEMON -- $DAEMON_ARGS
         failed!
         wiregated
        Grüsse Bodo
          Bodo,
          hast du schon Stefan's Tipp unter https://knx-user-forum.de/145555-post16.html angeschaut/ausprobiert? Bei mir hat es geholfen.
          Gruss, Felix
            Hoi Felix
            Auf der Konsole ging's dann.
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Alles wieder glatt...
            Aber jetzt hab' ich einiges mehr an Paketen drauf, mehr als gewollt.
            Grüsse Bodo
              Ich häng mich hier mal dran ...
              Wollte mein (fast)neues Wiregate mal auf Patch27 updaten und bekomme folgende Meldung unter "Liste der zu aktualisierenden Pakete":
              E: The package collectd needs to be reinstalled, but I can't find an archive for it.
              Patch27 wurde nicht installiert. Mach ich was Falsch?
              -- Thomas alias "Sepp0987"
                @Thomas: nein du machst nichts falsch..
                Entweder Wartuns-VPN aktivieren + PN/mail mit WG-Nummer
                Oder folgendes auf der ssh-Konsole als root
                apt-get update
                killall collectd collectdmon
                apt-get install collectd
                Makki
                -> Bitte KEINE PNs!
                  makki,
                  danke für die schnelle Antwort.
                  Habe die 3 Kommandos ausgeführt und bekomme am Ende:
                  Verarbeite Trigger für initramfs-tools ...
                  WARNING: /boot is ro mounted.
                  update-initramfs: Not updating /boot/initrd.img-2.6.26-1-486
                  Fehler traten auf beim Bearbeiten von:
                  collectd
                  >> ok oder nicht ok?
                    Problem gelöst - danke Makki.
