Berker B.Cube and programing button
    Sorry that I write in English but don't speak German.
    I bought some buttons Berker B. Cube. I would like to program them today but I can not find a way to address these buttons. They do not have the programming button, also probably need to press a key combination. I tried everything without effectively.
    Thanks for help!
    Grregg
    Programming is always made on the bus coupling unit, not on the push button sensor itself. The BCU is not inserted into ETS.
      Berker B. Cube has integrated BCU. Probably, instead of programming button I have to pressed down some key combinations like the buttons jung. Unfortunately, today is Saturday and I can not ask directly Berker.
        I cannot find it on the german page. Do you have an url? Or a part no?
          Sorry Matthes, but "always" is not longer true. E.g. the new TS 3 from Gira has the programming button instead of the necessesary "Busankoppler 3" which has none.
          @Greg: where is the location "ce" you stated in your profile? Please correct.
          Gruss aus Radevormwald
          Michel
            B.Cube is a new product and I coudn't find it in catalogue. But berker Q1 is very similar.
            Catalogue
