Components not working anymore (MDT and Ekinex)
    Hi all,
    Since 2 years, I am running a KNX system at home without any problems untill yesterday evening. My MDT AKS-2016.03 stopped working. The KNX connection seems to work fine because when I switch a light on/off the LED on the unit is still working but NONE of the activated relays are working. Even when I try to switch the relays by hand....
    Also my Touch and See interface from Ekinex stopped working.... It seems to stuck in a reboot and this problem started 2 days before.
    Anyone have had the same problems?
    Did you check the voltage on the bus? Could be to low for activating the relays but still enough for the electronic to work. Should be around 30V.
      Thank you, That is a good option. Will check that tonight.. My psu is the MDT STR-0640.01
      One remark, all my 4 AKD-0401 dimmers are working properly.
        In the past, we had quite a few cases here where some (not all) actuators showed strange effects -> low bus voltage due to defective supply (often MDT 640mA).
          Yes, it is the psu. I am using the STR 0640. and both outputs deliver 21 volts. way too low.
            Pls contact your dealer or our support directly, PS will be changed fast by pre-exchange.
