pico-PSU
    HS/FS pico-PSU
    Hello,
    I got my PicoPSU, but no doc in the box.
    The device is slightly different as the one from the the picture
    Can someone help me with a doc, drawing or whatever assembly instructions ?
    Thanks
    @Moderator
    I was unable to reply to my own post.
    I got many "Error from Server" and finally dropped my message anywhere, hoping for good will
    Sorry
    Hello,
    Finally, I have my HS running like before.... it took some time
    Thank you for your help
    Zuletzt geändert von Warichet; 24.06.2019, 07:38.
      That is the one I regularly use:
      https://www.amazon.de/PicoPSU-90-DC-...gateway&sr=8-3
      The ATX cable is not necessary.
        Hi Matthias,
        It's good to have you on-line
        Thanks for the picture.
        When looking at it, you see 3 small pictures on the left.
        The 3rd picture is Exactly what I've got
        The second picture shows the installation, but this is not on a "kleine zwarzie" , some components are rotated 1/4 turn.
        It is probably a EPIA 800A or higher level with a VIA C3, mine is probably an EPIA 500 with VIA C3, 533 Mhz
        So, if I buy another kit, chances are it will be the same as the one I've.
        Any idea ?
          Your black HS 2 (Net) may have this http://cdn.viaembedded.com/eol_produ...anual_v1.2.pdf mainboard.
          • Plug in the yellow 20-pin-PSU into the ATX connector on the board,
          • connect the white PATA-connector to your DOM,
          • don't use the black and small white plug,
          • connect your external power supply to the jack,
          and you're done.
          Gruß, Rainer
            Zitat von Warichet Beitrag anzeigen
            Hi Matthias,
            Any idea ?
            I will send a picture of my installation of picoPSU, and you one of your board I have seen "millions" of HS2 and HS3 from the inside, a pico psu will always work.
              Hi Taxus,
              Long time, no seen
              Yeh, that is my beloved HS2
              To start, I ripped out the cable network
              Plug in the yellow 20-pin-PSU into the ATX connector on the board, .
              OK. That was an easy one
              connect the white PATA-connector to your DOM,.
              You lost me.
              - PATA: that is a big, 4 wire connector (red, black, black, yellow, usually for disks) ?
              - DOM: Disk on module ? here it goes about the Flash, with a tiny 2 pin connector ?
              Do I need to remove cables from the big, yellow connector ?
              OK
              Wire is 20cm too short
              and you're done.
              Mmm, I love that sentence
              Thank you for your patience with a dummy
                Hi Taxus, Long time, no seen
                Yepp. And now you called for help, so here I am .
                Yes. For drives like floppy, CD-ROM, IDE-HDD used in the early times of personal computing .
                Yes. The DOM was connected by an adapter cable 4-pin (PATA, white) <-> 2-pin (tiny).
                Just reuse the old one.
                No .
                A pair of pliers will do the job. Cut off the jack of the picoPSU and connect the wires to the original cable. Solder the wires or use Wago 221-412 e.g.
                This gallery has 2 photos.
                Gruß, Rainer
                  OK, thanks
                  I've done my home work, picture attached, I think it should be OK
                  and indeed, it is simple
                  I would apreciate your comments
                  This gallery has 1 photos.
