- √ - EIBD and Siemens N146
    Can a Siemens N146 be used as an eibd IP interface ?
    Yes, I did SuFu, and read many posts about the topic, but everywhere, the N148 is recommended. This makes sense because of the price difference. If I missed the post, please be so kind to point me to the right place
    My question is specifically, can a Siemens N146 be used as an eibd IP interface. If yes, what would be the startup parameters of eibd ?
    Thank you
    eibd -D -T -S -d -i --pid-file=/var/run/eibd.pid ipt:192.168.0.50
    Marc
      Hi Marc,
      Thank you for the detailed reply.
      Any idea if the N146 will work with eibd ?
        Hi
        Yes, shall work fine
        Grüsse Bodo
          Yes, I do have the Siemens N146 IP Router and that are the starting parameters in my init.d file.
          Marc
            That's what I thought, but was unsure.
            I guess I can set it up, as a single tunnel, just like a N148.
            Merci Bodo
              SupportedHardware
                Zitat von mkoegler Beitrag anzeigen
                Thank you, Sir !
