Error message while download
    Hello,
    After a system repair, I want to do a fresh download, but I get an error message
    Experte 4.5
    Übertragung wegen System-Fehler nicht möglich.
    Datei C:\Users\admin\Documents\Gira\HS+FS Experte 4.5\Projekte\Migration\Migration\proj.id
    kann nicht erstelt werden
    The error message is not very much explicit about the cause of the problem.
    I checked the file path
    >C:\Users\admin\Documents\Gira\HS+FS Experte 4.5\Projekte\Migration\Migration which is OK
    I checked the file
    >dir proj.id
    22/06/2019 13:19 55 proj.id looks OK
    >type proj.id
    79df8f06458beda2da44ff2bf3d3cc54
    20190622131905533 seems OK
    The data looks like a key or a checksum, so I don't dare to mess around with those files
    Any hint, please ?
    Rename this file to proj.id.old and try it again.
      Great trick !
      Worked first time :-)
      I thought all my troubles were gone, bad luck
      Now I've a bizarre thing:
      The transfer was OK, but it looks like that the HS is not connected (1.1.254 Gira FT 1.2)
      As an example: trying to close the gate via the Visu doesn't wotk, but manually pushing the "Open" or "Close" works OK
      NB: while I was busy, I've done an upgrade from 4.1 to 4.5 with a zip file from 4.1.
      A reset seemed to have cured the problem
      Zuletzt geändert von Warichet; 27.06.2019, 17:36.
