hsav hsupload
    HS/FS hsav hsupload
    Can someone explain me or point me to the doc about how these files work ?
    hsav
    hsupload
    <my-name.htm> with the actual credentials
    the synch
    I understand there is a file transfer (at login time ?) but don't understand how the thing works
    I tryed several combinations without success, my original password is lost
    Thanks for your help
    The extract of <my-file.htm> might be usefull
    <html><head><title>Login</title><script type="text/javascript">
    // *** Hier die Daten eintragen ***
    var xxLoginUser = "warichet";
    var xxLoginPass = "bxxxxx";
    var xxLoginDesign = "GIRA1024";
    var xxLoginRefresh = "R1";
    Zuletzt geändert von Warichet; 21.07.2019, 13:16.
    Can you show your hsupload folder?
        it's empty?
          Here it is.
          Need some other ones ?
          Thank you for looking at my problem
          This gallery has 1 photos.
            It is Ajax-Visu .... http://www.hs-help.net/hshelp/gira/v...ajax_visu.html
              Thank you !
              Indeed, it is a Ajax Visu
              Can you add a few words of explanations, Please ?
              It would help my learning process
                Sorry, I don't even use the Ajax-Visu and I can't tell you much about it.
                Your searched password should be one of your users in Gira Experte:
                  OK, I'll check again
                  I thought I'd have done it, but think It needs an upload and reboot each time
                    So far, I'm able to manually boot the Visu, that is:
                    http://192.168.xx.xxx/opt/hsav/dog.htm
                    but then it stops
                    If I push with another command, it starts the Visu as normal
                    I can browse from page to page
                    Reading the Ajax manual didn't make me any clever.
                    All I see is
                    2.5. Start der Visu
                    "Die HomeServer AjaxVisu wird durch den Aufruf der Datei startgast.htm in einem Internet- Browser gestartet: "
                    "https://IP_des_HS/FS/opt/hsav-gira/startgast.htm"
                    So, I still miss a couple of lines to make it fly
                    Thanks for any tip
