I've used the SuFu but didn't help this time.
I'm installing a N48/22 according to the doc
I've assigned a fixed IP and a PA.
The LED on the front blink
The procedure about pushing the Prog button until the LED goes out seems to work.
The procedure about pushing the Prog button more the 5 sec but less then 10 seems to work, the LED blinks rapidly.
With ETS, the N148 replies at "Device Info".
The N148 replies at Ping
Everything seems to work normally, but in ETS 3.0e, I see only 1 channel, instead of 4.
I'm sure I forgot something, but what ?
PS: I didn't go through the intermediary step via DHCP, but assigned directly a fixed IP. I hope this is not the cause.
