Convert to string in HSL2.0
    HS/FS Convert to string in HSL2.0
    I'm making an AXIS PTZ module and everything is working like a charm.
    But 1 small issue i solved but dont understand why it happend.
    in the python file i have this part:
            #ophalen variabelen
            ipadr = (self._get_input_value(self.PIN_I_IP_ADRES))
            ptz = (self._get_input_value(self.PIN_I_PTZNUMMER))
            user = (self._get_input_value(self.PIN_I_USERNAME))
            password = (self._get_input_value(self.PIN_I_PASSWORD))
            #url creeeren
            ptz_url = ('http://'+ipadr+'/axis-cgi/com/ptz.cgi?gotoserverpresetno='+ptz)
    The problem is that ptz was a number before but i needed to convert it to a string to apply it in the url.
    So in python i did this:
    ptz = str(self._get_input_value(self.PIN_I_PTZNUMMER))
    Which worked when tested in python (i replaced the self. part with a variable, so ptznummer = '5' ptz = str(ptznummer))
    But when i uploaded the logic module it would not work (no errors)
    I "fixed" it by changing the PTZNUMMER to a string instead of a number.
    But that also means i have to change the number to a string in my logic at a point and it seems a step to much.
    Anyone here know why it wouldnt convert to a string when uploaded?
